0 members (), 140 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#1041688 07/11/2014 3:16 PM
I am just getting started with a first plan for my COE. Would COEs have been standard 6V systems?
How can I test if this is a 6V or 12V system without a battery? Would the generator or coil be labeled or can I test those somehow for voltage?
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
6v for 1954 Chevrolet COE.
A black oval metal tag on starter and/or generator usually indicates 6v (red tag for 12v).
Check the head lamps - they might indicate 6v or 12v (or, have a ID/product code you can look up).
Original Delco coils are often marked as well for voltage.
https://www.flickr.com/photos/advance-design_parts_co/sets/72157631868452754/
I think you will find a Delco 6 volt regulator had the cover bolts in opposite corners at the top. The 12 volt version had the cover bolts down much lower, centered on each end.
1951 1 Ton Completed
