0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Well, it looks like my '51 1/2ton may be missing something.. (it was in pieces when I bought it) there two supports on each side attached to the frame to support the runningboards...and should be three each side, looks like one was torched off about an inch from the frame and the other is missing rivets and all. Would all three supports be the same? I've looked around some vendors, but can't seem to find this part - does anyone know a source or did I miss something in the catalogs? Thanks for any help! | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I got one from Mothertrucker who you can find in the swapmeet section. You drill out the large rivets and then install the new bracket with carriage bolts. From the outside the round head looks just right.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Keep in mind that "carriage bolts" are only grade #2 bolts.........
*** GMC ***
| | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Check with some of the vendors (click on the Links button at the top of this page). I got 2 used running board brackets for my 1953 Chevy 3604 a few years ago from Jim Carter. Several of the other vendors have good stocks of used parts also.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | True, very soft grade 2 bolts. I believe there are three holding each bracket times three brackets so that is nine per side. I know that will hold my little old 165lb frame. But then, who steps on the running board anyway? What would you use? I certainly can't do any rivets like that.
| | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | I don't have a rivet gun either.......... :rolleyes:
Something wrong with #5 bolts? You can even find them Cad. plated if you obtain them from outside of "The Land of Fruits and Nuts".
Carriage bolts come in brass too (There are nine, right?) :p
*** GMC ***
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | What grade steel were the original rivets you think? Would that be a hardened rivet?
| | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Winter is starting folks............... :rolleyes: Always have to have the last word, huh Tony M.? From you I would expect nothing less (and I know there will be more). Geez, just a reminder about the carriage bolts.......  It was nothing personal  .
*** GMC ***
| | | | | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Thanks everyone - I checked Jim Carter they don't have anything new but are going to call me back about used ... American Classic sell used ones but you have to buy 6 ($135.00) - still looking... | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Running board brackets are avaliable individually in the Swapmeet section. Just post a Wanted Ad  | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Last word me?
| | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | ALL 6 BRKT'S ARE DIFFERENT ON A 1/2 TON
THERE ARE 4 RIVET'S PER BRKT.
PUT GRADE 8 BOLTS IN THERE.
I HAVE GOT SOME FROM HEAVY CHEVY & BOWTIE BITS.
WHEN YOU ORDER, TELL THEM L/H OR R/H
1.FRT 2.MIDDLE 3.REAR
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Truckman's got it! All are diff. Diff angles, lengths, the whole works! Bow Tie Bits is one of best for used. I just threw out a bunch off a 2-ton that were laying around when I cleaned garage. They don't work on small trucks either though! :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Aug 2002 Posts: 141 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 141 | gobsow what ever happened to the " Charlies" now that someone is actually close to me I'll search around down soyth of you see what I can turn up "how bout them " 'eers"  | | | | | Joined: Jan 2003 Posts: 19 Member | | Member Joined: Jan 2003 Posts: 19 | gobssow: Tom Myers truck parts in Miami, Oklahoma should have all the runningboard brackets you need. I've gotten several of them from him for my 3/4 ton 52. I used grade 8 fine threaded bolts, grade 8 washers and grade 8 Nylock nuts all from Fastenall (they are a national firm you can find them in the business section of you phone book). Put a washer under the bolt head, and another between the frame and Nylock. As the others have indicated here you will need a running board bolt kit to fasten the RB's to the bracket, Tom should also have those if he doesn't try Chevies of the 40's in Washougal, Washington. If you need the part numbers for thr RB's drop me an e-mail and I will look em up for you. BuBBAB52  | | |
