5 members (mick53, Grandpa C., lumbersawyer, Nick in Manitou, Wally / Montana), 127 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
#104150 01/15/2003 11:39 PM
Well, it looks like my '51 1/2ton may be missing something.. (it was in pieces when I bought it) there two supports on each side attached to the frame to support the runningboards...and should be three each side, looks like one was torched off about an inch from the frame and the other is missing rivets and all. Would all three supports be the same? I've looked around some vendors, but can't seem to find this part - does anyone know a source or did I miss something in the catalogs? Thanks for any help!
I got one from Mothertrucker who you can find in the swapmeet section. You drill out the large rivets and then install the new bracket with carriage bolts. From the outside the round head looks just right.
54 3100 with 235
62 flatbed dump C60 with 261
Keep in mind that "carriage bolts" are only grade #2 bolts......... eek
*** GMC ***
Check with some of the vendors (click on the Links button at the top of this page). I got 2 used running board brackets for my 1953 Chevy 3604 a few years ago from Jim Carter. Several of the other vendors have good stocks of used parts also.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
True, very soft grade 2 bolts. I believe there are three holding each bracket times three brackets so that is nine per side. I know that will hold my little old 165lb frame. But then, who steps on the running board anyway? smile
What would you use? I certainly can't do any rivets like that.
54 3100 with 235
I don't have a rivet gun either.......... :rolleyes:
Something wrong with #5 bolts? You can even find them Cad. plated if you obtain them from outside of "The Land of Fruits and Nuts".
Carriage bolts come in brass too (There are nine, right?) :p
*** GMC ***
What grade steel were the original rivets you think? Would that be a hardened rivet?
54 3100 with 235
Winter is starting folks............... :rolleyes: eek
Always have to have the last word, huh Tony M.?
From you I would expect nothing less (and I know there will be more).
Geez, just a reminder about the carriage bolts....... frown It was nothing personal smile .
*** GMC ***
Thanks everyone - I checked Jim Carter they don't have anything new but are going to call me back about used ... American Classic sell used ones but you have to buy 6 ($135.00) - still looking...
Anonymous
Unregistered
Anonymous
Unregistered
Running board brackets are avaliable individually in the Swapmeet section. Just post a Wanted Ad wink
Last word me? smile
54 3100 with 235
ALL 6 BRKT'S ARE DIFFERENT ON A 1/2 TON
THERE ARE 4 RIVET'S PER BRKT.
PUT GRADE 8 BOLTS IN THERE.
I HAVE GOT SOME FROM HEAVY CHEVY & BOWTIE BITS.
WHEN YOU ORDER, TELL THEM L/H OR R/H
1.FRT 2.MIDDLE 3.REAR
FRAMEUP TRUCKS - 47/55.1ST
STILL PLAYING WITH TRUCKS
Truckman's got it! All are diff. Diff angles, lengths, the whole works! Bow Tie Bits is one of best for used.
I just threw out a bunch off a 2-ton that were laying around when I cleaned garage. They don't work on small trucks either though! :p
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
gobsow what ever happened to the " Charlies" now that someone is actually close to me I'll search around down soyth of you see what I can turn up "how bout them " 'eers" eek
gobssow:
Tom Myers truck parts in Miami, Oklahoma should have all the runningboard brackets you need.
I've gotten several of them from him for my 3/4 ton 52.
I used grade 8 fine threaded bolts, grade 8 washers and grade 8 Nylock nuts all from Fastenall (they are a national firm you can find them in the business section of you phone book). Put a washer under the bolt head, and another between the frame and Nylock. As the others have indicated here you will need a running board bolt kit to fasten the RB's to the bracket, Tom should also have those if he doesn't try Chevies of the 40's in Washougal, Washington.
If you need the part numbers for thr RB's drop me an e-mail and I will look em up for you.
BuBBAB52 grin
