1 members (klhansen),
90
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Will a SM420 trans bolt up to a 1942 Chevy 6 cylinder engine bell housing that has a 4 speed in it????? Thanks!!!
Marv. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If it has the original bellhousing it won't, the bolt pattern on the SM420 is different. | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | You will need to locate a bell housing from something like a 48 truck. This bell housing, however, lacks a place to bolt up your brake, clutch pedal assembly (if you have 1/2 ton, 3/4 ton no problem). The next issue is that the SM420 is approximately 2" longer than the original 4 speed crash box requiring a shorter torque tube and propeller shaft. I am doing this on my 1939, and have gotten this far. There may be other issues that I have not yet addressed.
| | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | I guess I should have made my question clearer, the truck is a 1942 one and a half ton ( 1-1/2 TON ) with the rear motor mounts on the bell housing. What other bell housings will work with SM420 that has the motor mounts on the bell housings. The engine I am putting in is a 1962 235 6 cylinder. I have a open drive shaft no torque tube. Hope this clears things up a bit. Also what years, makes and models trucks did the SM420 come in. Thanks again!!!!!!
Marv.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Bellhousings that accept the 1942 mounts and SM420 transmission are 1948-53 truck. SM420 started in 1948 and I believe stopped in 1972.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That really sounds interesting Barry. I've never heard of any SM465's being installed in and AD before. Are you sure about the only mod being to bore the pilot hole in the bell housing? Have you installed one and if so I'd really like to see a couple of pictures of it. I just scrapped out an SM465 that I'd been dragging around for 10 years. Those are really a nice transmission and should be much more readily available since they were made all the way up till '91. Using it with the stock drive shaft could present a problem so I would think in some cases you would need to have a custom drive shaft made. Novak has some interesting history and information on using this transmission. http://www.novak-adapt.com/knowledge/sm465.htmDG
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I am pretty sure the floor cover would need modifying,they have a tall cover.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I didn't notice but are the gear ratios the same as the SM420? Of course I understand that 4th. is 1:1 just wondering about the others. I've really found no problem with 2nd., 3rd., to 4th. in the SM420. Have only used 1st. sometimes like around the grounds at a car show but even then, 2nd. is fine usually.
DG
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | SM465 Gear Ratios are: First Gear - 6.55:1 Second Gear - 3.58:1 Third Gear - 1.70:1 Fourth Gear - 1.00:1 Reverse - 6.09:1 SM420 1st Gear Ratio .... 7.05 2nd Gear Ratio .... 3.57 3rd Gear Ratio .... 1.70 4th Gear Ratio .... 1.00 Reverse Gear Ratio .... 6.78 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don't gain anything there do ya Tim! tks
DG
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
No gain/advantage: it looks like using 2nd gear in either transmission to "take off", unless you have a low-ratio rear end, or you want to burn rubber, or you need to pull a car up a ravine, or you are entered in a slowest vehicle race.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sm420 was last used in 1967. All trucks 1/2 to 2 ton. 47-67. Chevy and gmc Just in case someone with a 1947 truck and an "oddball" 4-speed transmission reads this in the future: The SM-420 transmission might have been manufactured by GM from 1947-67 (as shown by Novak), but it was used in 1948-1967 model Chevrolet trucks (probably/maybe in late '47 production, after the 1947 4-speeds ran out of inventory). | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | My understanding is that the SM465 is not only longer but bigger than a SM420, I was hoping not to do any cutting of the floor pan. Is there any other transmissions that would replace the original 4 speed in my truck that have synchros in them and is not any larger in size? Also what years and makes of trucks would they come in. Thanks to all for your help!!!!!!!
Marv. | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | Don't know if this is relevant but I've seen threads discussing using early S-10 T-5 transmissions behind the 235 engine. I believe they are 5 speed fully synchronized with better ratios. A search on using T-5 should being them up. | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi Marvin I have made this same conversion many times. The key is to get a 1947-53 Chevy truck 6cyl bell housing BUT the 3 point mounting bracket for the clutch and brake pedals must be added. The bell housing to frame mounts are stock items.....there are two different mounts and I think you will need the ones for the 1942 crossmember.I do have one of these modified bellhousings in stock if needed...$240.00 plus shipping form California Brian | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | repguy Thanks for the offer to sell me a modified bell housing but that is out of my price range at this time. Has anyone seen or made a bracket that will mount the clutch and brake pedals once a 1948-53 bell housing is used???? Send me pictures or links. Thanks to all so far!!! 1-262-392-2989 or [email protected]Marv. | | |
