4 members (Robert Crandall, mick53, Danielbolt, 1 invisible), 165 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
Hello All
Does anyone have a picture of what the front motor mount(s) look like on this block. Per the casting number table it has side mounts. I don't know what these look like and/or if I can make them work for my situation. I have a single centered mount location.
Any picture of this would help. I have a chance to get one of these motors and want to make sure it will work.
Does any one know a link to a picture of this engine front mount?
I'd like to see exactly what it looks like.
maybe cletis will chime in, he knows these engines really well,
I thought one could do a little welding and make most mounts work ..but
Redryder pix
My Hotrod
Leo Offline
Moderator
Moderator
I can't help you with links or motor mount info, BUT, I wouldn't let this engine get away. If you have a chance to get it, just get it.
1 Offline
The older engines used a timing cover for a front engine mount, that has 2 studs mounted on the bottom. Any of those older covers will fit. GRAB that engine, no matter what.
Joe
The older I get, I only want to work on older rigs.
Thanks guys for responding. I've got a 36 chevy master 5 window coupe I'm finally getting started on. Had the car more than 40 years. Really got my heart set on doing old school. Just want to make sure I can make the mounts work. Thanks again.
If it is a mid 50s or later engine the mount looks like this. Earlier engines use the lip on the plate behind the timing gear cover like Chevy sixes. If yours doesn't have the lip, one from a Chevy six will fit it.
I have the mount assembly for the side mount block. The maintenance manual has an illustration of the mount here.
http://chevy.oldcarmanualproject.com/gmc/5559mm/5559mm359.html
The yoke on the front of these engines is missing the rubber cushion that would sit on the crossmember, and another rubber steel part that sits under the crossmember.
1 Offline
I just went and looked at my "side" mount. This amounts to a bracket that is " u "shaped. It bolts to both sides of the block and at the bottom center, under the timing cover, is your 1 bolt rubber mount. This could also be modified to work for you.
Joe
If you have another 1937-1955 chevy 216, 235, or 261 motor, or an older gmc 228, 248, or 270 motor, the timing plate can be swapped. It is a bit of a project to swap the timing plate as the following have to be removed and replaced.
Valve cover
Rocker assembly
Push rods,
Lifters,
Side plate,
Fuel pump,
Oil pan,
Harmonic balancer,
Timing cover,
Camshaft
Not all that hard, just time consuming.
Man, what a bunch of good guys. Thank you for all the info. It helps me a great deal. Thanks again
