1 members (3800GUY),
89
0
Mod | | | Forums66 Topics128,189 Posts1,057,336 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | still trying to figure out what gas tank will fit between the frame rails of my 46 1/2 ton, anyone done this? and what tank did you use? | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Not in a '46 , but I tried 1 in a '55.1 ,the only place it would fit was between rear-end and back bumper . It was in the way of everything .the filler tube was a pain , the tail pipes in the way , brake line , I gave up and put one behind the seat ....
" STUCK IN THE '50'S "
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I got a Suburban/Panel truck tank that fits between the frame and drive shaft for my 1956 Pickup project. I put the filler door on the passenger side rear fender. I did it this way because I didn't want to lose my spare tire and I didn't want gas fumes in the bed. I plan on having a bed cover to keep my luggage dry when I travel, so one or two drops of gas in the bed would have my cloths smelling like gas... Just another option on where to put the tank. Mike B  | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Here is something similar but is a bit bigger. I'm looking to do something like this for my '40. I have to do something before I drive it again because I welded up the fuel opening in the cab! I'll use a filler from a Lil Red Express that is exposed on the outside and enters through the panel below the bed. Not sure if the tank in this link will fit though. Haven't checked.
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEG159&i=|gas tank||||
After looking at JC's description a bit closer, maybe it is the same tank as suburban/panel but includes all the mounting hardware.
Dennis
40 Chevy 1/2 ton
