2 members (39Master85, 2Wheels),
105
Mod | | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Will a 1955 Chevy with a 6 cylinder 235 engine 3 speed overdrive trans fit behind a 1957 GMC 6 cylinder with a 270 engine with a SM-420 trans. Can the two be swapped out????? Thanks!!!!
Marv. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Yes, It will bolt up to the bellhousing same as the SM420. You will need to modify the driveshaft and obtain the column shift linkage rods and components. Fred
| | | | | Joined: Mar 2013 Posts: 224 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 224 | that makes a sweet set up! I have a friend with a 49 1/2 ton with a 261 and a 57 3spd overdrive. he has the kick down on the gas pedal. I just drove it a few days ago , it sure is nice to drive. the only better way would be a later Saginaw all synchromesh 3spd w/od. Jay D. | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That is a good article. More OD info here. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Thanks!!!!! to all for your help.
Marv. | | |
