5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
Will a 1955 Chevy with a 6 cylinder 235 engine 3 speed overdrive trans fit behind a 1957 GMC 6 cylinder with a 270 engine with a SM-420 trans. Can the two be swapped out????? Thanks!!!!
Marv.
Yes, It will bolt up to the bellhousing same as the SM420.
You will need to modify the driveshaft and obtain the column shift linkage rods and components.
Fred
that makes a sweet set up! I have a friend with a 49 1/2 ton with a 261 and a 57 3spd overdrive. he has the kick down on the gas pedal. I just drove it a few days ago , it sure is nice to drive. the only better way would be a later Saginaw all synchromesh 3spd w/od.
Jay D.
Good description of the trans operation here:
http://www.fordification.com/tech/overdrive.htm
That is a good article.
More OD info here.
Thanks!!!!! to all for your help.
Marv.
