7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert), 99 guests, and 1 robot.
Topics128,137
Posts1,056,430
Members48,441
#1040358 07/06/2014 3:13 PM
I have a '53 3100 half-ton with the original 216 engine. Should the dipstick tube be straight or curved? Mine has a pretty good curve to it and the dipstick is very hard to get in and out.
http://lymanhall.smugmug.com/Other/Other/i-qCjb2M4/0/M/DSC_1297C-M.jpg
I haven't been able to find any pictures of the right side (passenger side) on an original 216.
1953 Chevrolet 3104 1/2-Ton
More pix
It should be straight. It seems to me I had the same problem, and someone said that it was bent by a previous owner.
The tube is easy to replace, it just pulls out of the block. You can replace it with a new tube of the same diameter cut to the correct length.
Here is a picture of Denny Graham's engine:
http://www.pbase.com/dennygraham/image/137589816
The tube is 3/8" in diameter, and on my engine it rises about 5 7/8" above the block.
Thanks Stove and Brad. I put the tubing bender on it and tugged it back straight, and now the dipstick goes in easily and even shows the right oil level. I appreciate the help!
More pix
