8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible), 57 guests, and 4 robots.
Topics128,075
Posts1,055,919
Members48,429
#1039817 07/03/2014 8:43 PM
i'm pulling my 64 sm420 apart. when i pulled the front pilot shaft out 16 needle bearings fell out . is this what is called the pocket bearing? and stuck deep in the back was a spring steel type of a retainer.is this part of a cage. did this tranie eat itself up ? i did not see metal parts or shavings. i'm only doing the upper bearings.how do i put the needles back? with heavy grease? the retainer thing was laying loose in back of pilot shaft so i don't where it goes.i hope you understand what i'm trying to say.
art
art 444 #1039832 07/03/2014 10:18 PM
Here is a detailed slide show on the SM-420. They did not change much over the years. Slide 22 shows the needles you refer to I believe?
https://www.flickr.com/photos/advance-design_parts_co/sets/72157632620943718/
art 444 #1039844 07/03/2014 11:50 PM
WOW now i get it thanks so much
art
art 444 #1039879 07/04/2014 2:41 AM
Probably don't need this Art, I didn't look at Brads slide, but
the retainer keeps the needles in place and gets pushed to the
back of the bore when you install the shaft. Just make sure
there are no gaps when you finish loading the bearings and
you will know that you've got them all.
http://www.pbase.com/dennygraham/image/137529544
DG
Denny G
Sandwich, IL
art 444 #1039983 07/04/2014 3:37 PM
Bearing retainer pushed to the back? Guess what I found in there when I looked. I never knew, my life just became a good bit easier on the next rebuild!
THANK YOU!
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
