3 members (klhansen, 3800GUY, 1 invisible),
63
Mod | | | Forums66 Topics128,153 Posts1,056,847 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | I purchased an original stamped bed, the link has pics of it as received. Ive done the metal work on the frame and cross members, its now all straight. it has some hacked together crossmembers that arent original, but very heavy. Im staring at it trying to figure out how best to mount it. please help https://plus.google.com/photos/118219121658359708127/albums/6007181792383685601 | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Jay,
Nice original bed. That will clean up nice and look great with new wood.
What is missing are the long beams. A pair of 2x6 wooden beams standing on edge run from the front to back. They are attached to the cross members by stamped metal brackets. These brackets bolt to the 2 pairs of holes on each cross member and then are bolted onto the sides of the 2x6's.
U-bolts then drop over the wooden beams, down to the bottom of the truck frame and a steel plate and nuts hold everything in place.
Usually 2 U-bolts on each side for a short bed and 3 for a 12'bed.
I have a PDF of a document called "Unit Designed Chevrolet Truck Bodies". I don't remember where I found it, but about page 38 is perfect view of the bottom of your bed with the long beams and brackets in place.
I can email you a copy if you can't find it on line. | | | | | Joined: Sep 2010 Posts: 1,715 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,715 | I built my bed, here is the wood on the frame. It's held down with threaded rod and flat plates. click Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | jim i cant seem to find that pdf on the internet, so if you could email it or post it, that would be awesome.
ive got 3 original x members, im tempted to fabricate new ones for the super heavy i-beams that are the other x members.
having pics or pdfs would really help with that.
best regards | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I emailed the file. Some really great info.
I'm doing a new body on a '48 2 ton. | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | that is exactly what I was looking for! | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hi Wayne,
Do you still have to plans for bed? I want to build something similar on my 46 1.5 | | | | | Joined: Sep 2010 Posts: 1,715 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,715 | Hi Wayne,
Do you still have to plans for bed? I want to build something similar on my 46 1.5 The only plans I have are in my head and the photos in my photobucket. I did have the original beams that fit the frame. I used them as a template to make new ones. underside front behind cab center rear rails Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
