2 members (delky, dt235sd), 43 guests, and 3 robots.
Topics128,179
Posts1,057,157
Members48,465
I have a '51 1/2 ton with no spare tire carrier. Does anyone know if the under frame spare carrier is the same for '52?
Thanks for the help.
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
Just my two cents...alot of the trucks don't have a stock spare carrier cuz they were a pain in the arse to use. If you don't mind having something other than stock, check my pictures. It's a crank/chain operated [IE:SIMPLE] lift. Very easy to install. It's from an 80's mini-truck. wink
The 51 was a new design and is the same as a 52.They're mounted diagonally on the crossmembers and swing out. They worked better than the old slide out ones on the 50's and earlier.
Hey,
Wait a minute. There's nothing wrong with a slideout carrier.
[img]http://www.cmaynard.com/Truck/IMG_0665.JPG[/img]
Craig
To Russntustin,cmayna and especaially brjr51, Thanks guys. I'm just starting this project and it's amazing the stuff you all know.
Thanks again,
Mark
1951 Chevy 3100
Actually I do like what Russntustin did. Looks very simple to operate.
Craig
I don't know if this pertains to the thread, but I ran into a tire width issue when I put massive tires under the truck. Fortunately, I already had the stock "swing&drop" carrier under the truck, but the threaded rod and hook were too short and the wider rubber wouldn't fit. I took the hanger hardware off the frame and went to Tacoma Screw, they gave me threaded rods 2" longer than the rusty originals. I bolted the diagonal "saddle" to the new rods and now it holds the oversized rubber like it was designed for it (the bottom of the saddle is barely above the bottom edge of the pumpkin). I doubt you could do this with the earlier slide-out carriers (although Russ' design will take any size), so I prefer the swing-out carrier.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
