6 members (tclederman, fonz8261, TooMany2count, dt235sd, 2 invisible), 67 guests, and 1 robot.
Topics128,132
Posts1,056,386
Members48,441
#1039604 07/03/2014 12:16 AM
Howdy all! I got a 1959 chevy suburban, the 3rd member in the rear axle is toast! Can a 3rd member out of a 1964 Chevy 1/2 ton bolt right in?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
Sir Searchalot
Sir Searchalot
If you mean the ring and pinion assy, don't believe so. The 64 is a "C" clip installation and the 59 is not. You can put the whole 64 rear end on with moving the purches and adapting the Ebrake. I think 59 is 10 bolt and 64 is 12 bolt. 64 is very close to 59 WMS-WMS.
1955-62 1/2 ton center section will interchange.
My Blog
That is correct, the parts do not interchange. The '55-'62 rear does use C clips for axle retention, though, and the ring gear is 12 bolt with a 9 3/8" diameter. The only parts that will directly interchange are the C clips, and the spider gears can be swapped if 30 spline aftermarket axle shafts are swapped in.
Bill Burmeister
Thanks everyone! That's a big help
