3 members (klhansen, carbking, 1 invisible),
286
Mod | | | Forums66 Topics128,283 Posts1,058,521 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 42 | I have a 46 1/2 ton and I'm trying to install new front bumper and brackets but the space between brackets and bumper is too marrow by about a inch. My truck did not come with bumper or brackets so I had to buy new ones. I talked to supplier and they say they are the correct bumper and brackets. Would there be any one that could tell me what the distance is between the two bracket mounting surface's is. Thanks | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Have you tried, old online chevy manuals, i think you will find the measurements there. good luck | | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | The shop manual ( page 2-2) has a drawing that shows the measurement to be 25 and 45/64 inches.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | First do you have them on the correct side of the rail? Second consideration is an inch on brackets and bumper is not unusual. Once you get them where they go leave everything loose for the initial bolt-up.
KMAC | | | | | Joined: Oct 2012 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 42 | Thanks for the quick response. I do have all the sheet metal off of the front end which makes it easy to get to frame rails. I have all bolts loose and brackets spread apart as far as they will go and I am trying to to fit brackets to the outside of frame brackets. The distance between front frame bracket hole is 27" and the rear frame bracket is 27 1/2". My bumper brackets are about 5/8 to 3/4" too close to each other. Do you think I should try to spread brackets apart or change arc in bumper. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Brackets first, given they are reproductions it should be pretty easy. If the bumper is chrome changing it could result in the chrome separating.
KMAC | | | | | Joined: Oct 2012 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 42 | Thanks for the advise. I guess I will start on the bumper brackets. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Measuring from left center of the bolt, 17.25, 39.75, 57.00. This is around the arc of bumper. Might be off a little as I have bumper guard in the middle. The measuring inside the bumper left side 17.325, right side 17.5 and between the L&R 22 inches. | | |
