Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (46 Texaco, Bill Hanlon, FAST55, 50Chevy3100, carbking, NorCal52Suburban), 141 guests, and 5 robots.
Topics128,283
Posts1,058,519
Members48,490
I have a 46 1/2 ton and I'm trying to install new front bumper and brackets but the space between brackets and bumper is too marrow by about a inch. My truck did not come with bumper or brackets so I had to buy new ones. I talked to supplier and they say they are the correct bumper and brackets. Would there be any one that could tell me what the distance is between the two bracket mounting surface's is. Thanks
Have you tried, old online chevy manuals, i think you will find the measurements there. good luck
The shop manual ( page 2-2) has a drawing that shows the measurement to be 25 and 45/64 inches.
First do you have them on the correct side of the rail? Second consideration is an inch on brackets and bumper is not unusual. Once you get them where they go leave everything loose for the initial bolt-up.
KMAC
Thanks for the quick response. I do have all the sheet metal off of the front end which makes it easy to get to frame rails. I have all bolts loose and brackets spread apart as far as they will go and I am trying to to fit brackets to the outside of frame brackets. The distance between front frame bracket hole is 27" and the rear frame bracket is 27 1/2". My bumper brackets are about 5/8 to 3/4" too close to each other. Do you think I should try to spread brackets apart or change arc in bumper.
Brackets first, given they are reproductions it should be pretty easy. If the bumper is chrome changing it could result in the chrome separating.
KMAC
Thanks for the advise. I guess I will start on the bumper brackets.
Measuring from left center of the bolt, 17.25, 39.75, 57.00. This is around the arc of bumper. Might be off a little as I have bumper guard in the middle. The measuring inside the bumper left side 17.325, right side 17.5 and between the L&R 22 inches.
