| | | Forums66 Topics128,193 Posts1,057,241 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Or is water/exhaust heat just on split headers?
If it's something I should have (I'm in MN) what parts should I get? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | If your using a stock manifold and the heat riser valve still works it should be fine. I believe new bi-metal springs are available for them if your old one is broken or rusted. John | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Well I know I need some kind of heat, but I meant do I need additional heat over what's supplied by the heat riser on the stock setup. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you have the stock heat riser working that is all you will need. Make sure it is free and wouldn't hurt to install a new spring. You can go to National Chevy in St Paul, they are on Arcade St. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | If you have the stock heat riser working that is all you will need. Make sure it is free and wouldn't hurt to install a new spring. You can go to National Chevy in St Paul, they are on Arcade St. Awesome. I didn't even know about National Chevy. | | |
