| | | Forums66 Topics128,197 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | I bought a 1950 Chev 1/2ton. Where I am from, it seems like guys always put these old gems on 1/4ton frames. Would it not be just as easy to find a fullsize Chev shortbox frame which is 117"? I`m a newb at this. Is there just as much fab work either direction a guy goes? Or is the only reason to go 1/4ton is for the availability of these frames kickin around? Thanks,Darcy | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What is the model number for the 1/4 ton?
What is the wheelbase of the 1/4 ton?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | get out your tape measure and start hunting  many find S10 frames most compatible, if that's what you mean by 1/4T, but there's just as much work no matter, it's not "easy" to swap the chassis regardless of what's used Bill | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I never heard tell of a 1/4 ton Chevy?? The Willys Jeep was considered a 1/4 ton.
John | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Up here in Canada, 1/4 tons are the Chev s-10`s, Ford Rangers, etc. The S-10 regular cab long box is 117" wheelbase.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Darcy, browse the HiPo forum, there's been lots of AD frame swap threads over the years, frame length is only one of a number of considerations, track width might be a more important one
Bill | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You can modify the original frame for I.F.S., disk brakes ect.... if you want.
John | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Darcy, as red58 stated the track width is the bigger issue, and a reason many guys don't use the full size truck frame. It depends on what finished stance and look you're after. The s-10 is an easier swap on trucks like yours. | | |
