0 members (), 125 guests, and 10 robots.
Topics128,186
Posts1,057,211
Members48,465
I bought a 1950 Chev 1/2ton. Where I am from, it seems like guys always put these old gems on 1/4ton frames. Would it not be just as easy to find a fullsize Chev shortbox frame which is 117"? I`m a newb at this. Is there just as much fab work either direction a guy goes? Or is the only reason to go 1/4ton is for the availability of these frames kickin around? Thanks,Darcy
What is the model number for the 1/4 ton?
What is the wheelbase of the 1/4 ton?
get out your tape measure and start hunting grin many find S10 frames most compatible, if that's what you mean by 1/4T, but there's just as much work no matter, it's not "easy" to swap the chassis regardless of what's used
I never heard tell of a 1/4 ton Chevy?? The Willys Jeep was considered a 1/4 ton.
Up here in Canada, 1/4 tons are the Chev s-10`s, Ford Rangers, etc.
The S-10 regular cab long box is 117" wheelbase.
Darcy, browse the HiPo forum, there's been lots of AD frame swap threads over the years, frame length is only one of a number of considerations, track width might be a more important one
Thanks Bill!
You can modify the original frame for I.F.S., disk brakes ect.... if you want.
Darcy, as red58 stated the track width is the bigger issue, and a reason many guys don't use the full size truck frame. It depends on what finished stance and look you're after. The s-10 is an easier swap on trucks like yours.
My 46 GMC on Photobucket
