9 members (Bill Hanlon, UtahYork, BarryP, NorCal52Suburban, Hanks custodian, rfs56trk, Donf, Frank50, Gazz),
141
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | Any body pros out there? I have an bad ancient lead job on the front lower portion of my fenders that I need to remove. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Just like they put it on there with, a torch. Heat it up and it will fall to the floor. After you will need to clean off as much as you can with a "ROLOC" or similar so you don't remove too much metal.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | ok thanks. I kind of felt stupid asking but I think they stopped doing lead before I was born so I was kind of amazed when I uncovered it. oooh I struck lead! LOL
what's a ROLOC ? | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Be very care full when grinding or sanding lead, its very toxic! Try not to do it. Take a small torch and melt it off, then take a old shop towel and wipe as much off as you can. Then wear a good mask and get the rest off. Joe | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I believe ROLOC is a product made by 3M. It is a style or type of sanding / grinding disc.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | Make sure you have adequate ventilation too. Even when you heat it up, it will give off fumes and who knows what else. By the By, what color is that lead filler?
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
| | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | ok thanks everyone. I am definitely going to wear a good mask and do it outside. I'll post some pics when I have the body stripped.
the lead is gray in color and much harder than bondo. I would guess its at least 30+ years old? the truck has several layers of paint and 2 paint jobs ago they covered the entire fender with a coat of bondo. way too much bondo! anyway I was removing that with a scraper and chemical stripper then the last bit with a 4 1/2 grinder with sanding grit discs (probably same thing as roloc). That is when I hit the lead on the lower front fender. I felt some of the dust with my finger and it looked kind of like graphite or pencil lead. then I noticed the edge of the fender looks they just let it drip off. | | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | oh S%^#! I have some of that on my truck, and I may have breathed some of it in.  I guess I should get to the doctore. Dammit.
Jonathan S. Keffer
| | | | | Joined: Nov 2001 Posts: 72 Member | | Member Joined: Nov 2001 Posts: 72 | gmcfan Don't worry too much. I've worked with some ole cable splicers that wiped joints for years. They got a little goofy after a while and died a little earlier than usual but they were doing this 8 a day for years. As long as you melt it and don't grind it you're relatively safe. I use a respirator and try to work outside whenever I'm grinding or sanding it. Dennis | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Hey GMCfan, that goofyness sure sounds familiar don't it?
:p
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | GMCFan, I don't think a little will hurt or I'm in trouble too. Now if you did lead work for 20 years well then you probably have some problems. Even then I don't think the doctor can do much for that can they? | | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | nope, not much they can do, i think. I didnt breath that much in, anyway i have breathed in worse things than that, and im still here, but thats no excuse for not wearing a mask. Ahh, to be young and stupid again.
Jonathan S. Keffer
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think somebody should put this in perpsective, this is solder! Has nobody soldered pipes with lead/tin solder? Of course you don't inhale it but all the bodyshop guys that used it didn't die early. | | |
