1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Is there any advantage for me to swap the 16" 6 lug rims to 15" 6" wide, 6 lug rims the 15" came off a '48 panel, the 16" are orignal to my '55 1st ....
" STUCK IN THE '50'S "
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I'd say its personal preference. Many people run modern tubeless radials (which I would assume the 15" are) on their OE wheels if they're in good shape. | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | none of the rims have tires
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Thanks for all the help ..LOL
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 15s, being a 6" wide wheel, are most likely from a later truck. The main advantage I can see is that it opens up the opportunity for a slightly wider tire, and will be more stable with a modern size radial than the narrower 16" oem wheels. The disadvantage, though, is that you will be limited on overall diameter of whatever tire you decide to run. About a 28" tire is about all you're going to be able to get in a 15" that will work well on that rim.
Bill Burmeister | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Thanks , I'm keeping the 16's , what is the idea tire for my 55 1st ....
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | With the stock wheels, 215/85/16 is pretty close to the oe size, and are about as wide as you would want to go.
Bill Burmeister | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | one more question ....tubeless radials ??????
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Should be fine on those wheels, as long as the rivets don't leak.
Bill Burmeister | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Thank you. Been on this truck since July 6, 2013. Have about 3 more months to go ... had so much fun I bought a '50 Chevy coupe, now I can work on 2 at a time. I'll paint the rims and get the tires (casings as my Grand Pa called them)next mouth .... Thanks again
