0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#1038853 06/30/2014 3:15 PM
Is there any advantage for me to swap the 16" 6 lug rims to 15" 6" wide, 6 lug rims the 15" came off a '48 panel, the 16" are orignal to my '55 1st ....
" STUCK IN THE '50'S "
I'd say its personal preference. Many people run modern tubeless radials (which I would assume the 15" are) on their OE wheels if they're in good shape.
none of the rims have tires
wanderer1955 1st #1039018 07/01/2014 12:36 AM
Thanks for all the help ..LOL
The 15s, being a 6" wide wheel, are most likely from a later truck. The main advantage I can see is that it opens up the opportunity for a slightly wider tire, and will be more stable with a modern size radial than the narrower 16" oem wheels. The disadvantage, though, is that you will be limited on overall diameter of whatever tire you decide to run. About a 28" tire is about all you're going to be able to get in a 15" that will work well on that rim.
Bill Burmeister
Thanks , I'm keeping the 16's , what is the idea tire for my 55 1st ....
With the stock wheels, 215/85/16 is pretty close to the oe size, and are about as wide as you would want to go.
Bill Burmeister
one more question ....tubeless radials ??????
Should be fine on those wheels, as long as the rivets don't leak.
Bill Burmeister
Thank you. Been on this truck since July 6, 2013. Have about 3 more months to go ... had so much fun I bought a '50 Chevy coupe, now I can work on 2 at a time. I'll paint the rims and get the tires (casings as my Grand Pa called them)next mouth ....
Thanks again
