| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 25 | My '51 panel has bendix on the rear and huck on the front.
I'd like to but the bendix setup on the front so they match and would like to keep the truck 6 lug.
Is there a range of vehicles I could use as donors for the bendix setup or do i have to stick with '52 and newer AD only?
Anyone have a complete front setup they don't need? | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Contact me after the episode of TV show "The Hoarders" which features me airs. I will be the nutritionally well-endowed, good looking bald guy throwing stuff. Seriously, you shouldn't have too much trouble finding what you need, as lots of guys are pulling them out to upgrade to IFS.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | 1951 and up would have the bendix brake setup. If I remember right I had to drill 2 of the holes out in the spindles of the huck brakes to allow the bendix backing plate to bolt on.
John | | | | | Joined: Aug 2013 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 25 | I figured finding them shouldn't be a problem if you can catch someone at the right time before they toss the old parts.
Any idea what I can expect to pay for a bendix setup?
...and yes, I've read you have to drill out the lower holes from 7/16 to 1/2 inch.
Thanks. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I used the entire front brakes off a 57 half ton on my 46 half, bolted right on.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1951-59 will all interchange.
See the USA in your vintage Chevrolet! My Blog | | |
