| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | help please: i am a novice who will be working out of a driveway, i plan on buying a 58-66 chevy or gmc truck. i read the article on a "botched restoration" with hints on using products from eastwood and zero rust. i will be working out of my driveway/basement with resources limited to wire wheels and wire brushes,spray cans and paint brushes. assuming that i knock off as much rust as i can using the wire wheel/brush combo what is the absolute best product(along with proper steps) i can use for a rust free finish that will last. finally where does the much talked about miracle paint POR15 fit in to all of this rust discussion???? thank you for your help | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Yee Haw! Here we go again!! I will, as my contribution to the subject, point you in the direction of a real world test done several years ago on the motor mounts of a salt water fishing boat between ZR and POR. go to http://www.autobodystore.com/images/boattest.jpg The "after" pictures were taken after 16 months. This test was the make or break decision maker in the man's evaluation of whether or not he would sell ZR off his web site. POR had been the mainstay in his shop for rust control prior..... Bruce Palmer [email protected] | | |
