7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Interpretation assistance humbly requested:
1019S8274A
10 = 1/2 ton 19 = ? ? ? S = '58/59 model 8274 = sequential production # + 1,000 ? ? ? A = assembly plant ? ? ?
Is a USA (not Cdn) vehicle
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Miss Church, 1019S8274A You might have tried to use the information on on this website, but your sequence does not seem to completely match. Maybe someone else can interpret this? You might want to join the oldGMCtrucks.com discussion board. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 10 = 1/2T, 1 = 114" short bed, 9 should indicate engine see here, GMCs are confusing  Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 101= 1/2T short, next letter can be engine or assy plant, engine is either blank (6) or 8 for V8 (no 9's), if it's assy plant it's C, P or S (no 9's).... If I wanted to go out on a limb, I would say it's not a 9. The S is correct for 1958/1959 and the rest is sequence serial number. Have not seen "A" at end of USA GMC. Have owned 3. You say it's a USA vehicle and you are sure it's not Canadian. Canadian GMC's did have different numbering and they DID have "9" for 1959 and they DID have "A" at the end for GVW less than 6000. But they didn't seem to start out 101 as USA did. So misread, misprint or Hybrid number/hybrid truck. What wheel base is this Panel? Should be 114". Is serial plate on driver hinge pillar or outside firewall or just on Title?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Perhaps it was misread; am doing this on behalf of a colleague and will examine it myself and report in due course. It is a panel, not a short box pickup | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes a Panel, they made a long 1 Ton Panel also in 58, just wanted to be sure the actual Panel matches what the Serial says. A 101 Panel is the same wheel base as a short box pickup. Hoping the fourth digit is an "8", and the last digit is a "4".
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | It turns out nos. came from ownership (title) papers, not door jamb (serial no. plate missing). Therefore it was either misread at some point or, more likely, title is incorrect. Thank you for the assistance | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | (the plot thickens)
original plate has been located: 101 P 58274 A
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | 10 - 1/2 ton 1 - 114" (short) wheelbase P - Pontiac assembly plant 58274 - ? ? ? A - continues to be mystery digit | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes 1/2T short, 6 cyl, Pontiac, MI, 58274 should read S8274. (101 P S8274) the 7273rd off the line, I believe they started with 1001 or 1000. The "A" is an anomaly. I do not believe the plate is original. I believe the plate was redone by someone. You can buy those plates. They misread something somewhere. and stamped it wrong. I hope your friend has a Title in their name and I hope that if it was reconstructed, it was done through the DMV. If so, they would issue a new plate in most cases in U.S. If I was looking to buy it, I would be very concerned about the documentation. Like, why is the plate off the truck? Why does it not match the papers, etc. At any rate, I guess all you want is to cypher the serial. It is not altogether a proper number as far as I can tell. I have seen Chevy trucks with the "shadow" of the number behind the plate where they stamped the plate after it was installed, therefore indenting the pillar metal also. You may want to look there, GMC may have done that as well.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Yes, the 5 is actually an S (incorrect on ownership)
the A continues to be a mystery (checking today for shadow)
foregoing responses all greatly appreciated | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The first one was 1001 so number 8274 is the 7274th one. | | |
