2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#1036391 06/18/2014 9:20 PM
On the 57 GMC 370 LCF, on the left side of the transmission, there is an adjustable rod, about 2 ft. long, connected to the crossmember of the frame.
What is this for, and how do you know it's adjusted correctly?
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Which transmission does your truck have?
Bill Burmeister
The SM420 4-speed. GM.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Well, it doesn't say what it does, but here's the manual page explaining how to adjust it. I'm going to look further in the manual, just to see what it actually is for, because now you have me curious, too.
Bill Burmeister
Thanks, mine is so rusted, it would take some heat to move it. Does not look like it has ever been adjusted.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Guessing it is a brace only to ward off vibration or help with unwanted torsional movement, especially in low gear. Modern term is what NVH? Noise Vibration Harmonics? Without it shifter might move too uncomfortably in your hand...
Just guessing.
R-Bo
1966 GMC 305V6 in the family
Does the rod look similar to this one in the middle of the image below?
[img]http://www.surfacezero.com/g503/data/3764/2013-11-21_17_40_521.jpg[/img]
I have always wondered what the true purpose is as well.
Lots more pictures
Yes, it is similar to that except it is on the left side of the transmission and there is a yoke that bolts to the frame crossmember with adjustment there.
Also this is a 2 or 2 1/2 ton truck.
I am thinking R-Bo may be correct about stopping the shifter from moving under a load. But it seems to be going the wrong direction for that, more like to restrict forward and backward movement??
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
