| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | will a 235 from a 57 bolt into my 1950 3600 with 4 speed. Is this a better choice than my 216? | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | It's almost a bolt-in, just some possible issues with front motor mount adapting and an the position and length of the water pump. Both concerns are solved pretty easily. A post-1954 235 has a different, and "better" in the opinion of some people oiling system for the connecting rods, also slightly more horsepower than the 216. Jerry
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It's a better choice in that it's a later engine with a little more power and will be easier to obtain parts for through a local supplier, like NAPA. You'll have to drill the front engine plate or transfer the 216 one for the front crossmember and you'll have to use the 216 bellhousing for an easier fit. It's a good swap I think if you want to do it.
Drew
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe that you can use the front plate from your 216 on the front of the 235. Also with the water pump relocation plate you can use water pump from the 216 in it's original position. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | And BE SURE to make it where all the timing cover bolts screw in from the front.
Evan
