4 members (delwrench, Southerntruck, cmayna, dt235sd), 123 guests, and 3 robots.
Topics128,142
Posts1,056,490
Members48,442
#103730 02/03/2003 4:06 AM
I ran into a snag when trying to bolt the box up an a 51 3100 short box.On one side the upper frame rail that the wood block holding the back right corner of the box up is rusted and broken off just past where the block would sit.What guage steel is used on the frame and what is the best method of repair.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#103731 02/05/2003 5:30 PM
I have been going through the same thing, w/ many different oppinions on repairing methods, I had to cut a small section out of mine, and was able cut a patch out of an extra rear cross member I had. The gage appears to be 10ga if I am correct, I measured mine on one of the rear legs w/ a gauge. I cut mine out fitted the replacement section and then beveled the edges of both the patch and the chassis. I welded it in place w/ my Mig welder. I was talking to a guy the other day and he mentioned heating this area up before one welded w/ a Mig to get better penetration, I do not know if this is true?
#103732 02/05/2003 7:49 PM
Mine was the lower rail that rusted out and I just welded in a piece of 1/8" angle iron (2" IIRC) as reinforcement.
