7 members (Woogeroo, baldeagle, Hotrod Lincoln, Cletus1950, 3 invisible), 359 guests, and 4 robots.
Topics128,165
Posts1,057,087
Members48,463
I have a 42 chevy pickup Im wanting to convert from the 235 to chevy small block and 350 trans keeping the straight front axle and converting to updated rear axle. Does anyone have any insight or have done this conversion? I found this cross member here http://www.tdperformance.com/Universal-Crossmembers-With-Pads but Im not sure how to figure out what I would need for the trans mounting theres so many choices 3 inch drop no drop etc... http://www.tdperformance.com/Universal-Fit-Transmission-Crossmembers any advise would be greatly appreciated...Thanks
You might want to check out Chassis Engineering.
You need no further advice. What I really like about Chassis Engineering is they usually offer their swap kits in either weld in or bolt in style, something most others don't.
Evan
Before you do the SBC swap you might want to read about Gary's swap.
http://vortec4200.com/forum1/viewtopic.php?f=10&t=1099
keep it inline - 450HP is easy ....
Sir Searchalot
Sir Searchalot
Most of our vendors have the universal cross members and associated mounts. Bolt in is best for future changes. you can get one for the motor, mock it up with tranny and measure for the trans mount. All these things can be adjusted, modified, shimmed, spacered, fabed..... at mock up. Don't know about 42 but this has been done a whole lot with old trucks. Many, many how-to's
I did a 283, TH 350 in my 1946 1/2 ton some time ago. For the rear end I installed the "Pumpkin" from a 1956 1/2 ton with 3:38 RATIO. The pumpkin bolts right in to the 46 housing. You will also need to install new axel mounts and weld them solid. the rear end has held up fine behind the built up 283. I can provide pictures if you need them.
Rick :^)
