| | | Forums66 Topics128,167 Posts1,057,096 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 10 New Guy | | New Guy Joined: Sep 2013 Posts: 10 | I have a 42 chevy pickup Im wanting to convert from the 235 to chevy small block and 350 trans keeping the straight front axle and converting to updated rear axle. Does anyone have any insight or have done this conversion? I found this cross member here http://www.tdperformance.com/Universal-Crossmembers-With-Pads but Im not sure how to figure out what I would need for the trans mounting theres so many choices 3 inch drop no drop etc... http://www.tdperformance.com/Universal-Fit-Transmission-Crossmembers any advise would be greatly appreciated...Thanks
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You might want to check out Chassis Engineering. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You need no further advice. What I really like about Chassis Engineering is they usually offer their swap kits in either weld in or bolt in style, something most others don't.
Evan
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Most of our vendors have the universal cross members and associated mounts. Bolt in is best for future changes. you can get one for the motor, mock it up with tranny and measure for the trans mount. All these things can be adjusted, modified, shimmed, spacered, fabed..... at mock up. Don't know about 42 but this has been done a whole lot with old trucks. Many, many how-to's
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | I did a 283, TH 350 in my 1946 1/2 ton some time ago. For the rear end I installed the "Pumpkin" from a 1956 1/2 ton with 3:38 RATIO. The pumpkin bolts right in to the 46 housing. You will also need to install new axel mounts and weld them solid. the rear end has held up fine behind the built up 283. I can provide pictures if you need them.
Rick :^) | | |
