1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | Anyone know if the rear mounts on the crossmember of a 6400 are the same as a smaller truck ? I am specifically referring to the ones at Jim Carter, # ME 219. Old trucks The gal I talked with last week didn't know and I haven't gotten a chance to call the "tech Line" between 2 and 4 pm...  This is for a '57 crossmember and '68 bellhousing.
1952 Chevrolet 6400 flat bed
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | those mount pads work, no reason the model would be different if they all use the same engines and transmissions
Bill | | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | those mount pads work, no reason the model would be different if they all use the same engines and transmissions
Bill I tend to agree but all the sites list them for up to 1 ton. I didn't know if the 2 ton had a wider crossmember and needed a different mount.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the mount points on the cross member have to be in the right place and orientation to bolt up to the bellhousing, which is the standard - vendors only list all sorts of things "up to 1T" cuz they know nothing about the big trucks, they would prolly tell you all the cab parts only fit up to 1T  Bill | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | My parts books confirm the rear engine mounting pads kits are the same 54-59 Series 3-4-5-6-7-8, part number 3760997. Mike B  | | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | My parts books confirm the rear engine mounting pads kits are the same 54-59 Series 3-4-5-6-7-8, part number 3760997. Mike B  Excellent, thank you, Mike That confirms the belief they are all the same. I will get them ordered tomorrow. I'm hoping to start the 292 install in a couple weeks.
