| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | On the TF trucks, is there any need to glue in between the push pins on the door weather stripping? I know they need special attention at the corners and curves. Thanks.
Wayne.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | only useful to glue around the dogleg, and you really need to use the proper metal retainer strip on the bottom - there were also originally metal clips in a few corner places that are good to have
Bill | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Bill, there were 3 original retaining clips on the door. They were in the curves near the latch. This is an LCF and there are push pin holes across the bottom. Did not see a metal retainer. But there is only about a foot of "bottom edge" because of the big cut out for the wheels.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the pegs are still used on the bottom, don't know if the LCF had the retainer, but you might look for small screw holes toward each end of the bottom for an indication of it, on the regular doors it really is helpful because of the constant working of the seal with the open/close action of the doors, especially in freezing weather when the rubber can sometimes stick to the step from moisture there freezing - I think without a retainer, it'd be good to glue across the bottom
Bill | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Ok, I will look for evidence of ever having one. If not, maybe fabricate something just for good measure. Thanks for all the help. This is a first for me. I have restored a bunch of old cars and tractors. But I always took the glass work and weather stripping to someone else.
