6 members (homer52, TrknGMC, Ponchogl, klhansen, Robert Crandall, Hotrod Lincoln), 37 guests, and 3 robots.
Topics128,023
Posts1,055,371
Members48,420
Page 2 of 2 1 2
jimbo 24 #1033914 06/06/2014 7:03 PM
I have seen an engine with the looks of a 1953-55 first series engine, like this one, but cast much later. That engine had the passenger side pan rail bulged out like the 1955 second series-63 engines(1953-55 first would be straight down both sides). I would check the pan rails to confirm.
I just re-looked at the pictures of this engine and see a raised circle above the starter. I have seen this marking on another engine which was reported to be a 261(maybe Canadian).
My Blog
jimbo 24 #1033934 06/06/2014 8:38 PM
dave the pan rails do buldge out about half an inch. Yes there is a circle above the starter. my buddy says on the other side below filter, there are 2 looks like bolt holes but are solid. this makes him think its a 235 full pressure. keep the help coming and i will keep answering. I had 4 friends help me take truck apart and now it is just me putting it back together. I don't really know alot but with u guys help and me being persistent, i will try my best.
jimbo 24 #1034018 06/07/2014 5:14 AM
54-55
261
3703414
3733950 my #
3703570
3836850 my#
this is what i seen on 261 sight
jimbo 24 #1034374 06/08/2014 10:32 PM
can u have a 261 motor without the captain's bars
jimbo 24 #1034376 06/08/2014 10:46 PM
I have not seen a 261 without Captains bars or the circle your has.
My Blog
jimbo 24 #1034663 06/10/2014 3:51 AM
so now what
jimbo 24 #1034850 06/10/2014 11:55 PM
Gas Pumper
Gas Pumper
Its a 54/55 261 according to your numbers. Does this answer your question?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
jimbo 24 #1034888 06/11/2014 2:56 AM
yes it does. thanks so much
jimbo 24 #1034891 06/11/2014 3:09 AM
without captains bars
jimbo 24 #1035046 06/12/2014 12:49 AM
Gas Pumper
Gas Pumper
Yeah, all I can say is, the numbers, if read perfectly, is a 54/55 261. Since dirt and debris can change a 3 to an 8 or whatever, if its clean, and these numbers are good, its a 261.
I have seen so many anomalies with these trucks in parts, if seems that every now and then, maybe its Friday, the GM employee does the wrong thing and all comes together anyway. Maybe those captains bars are there.. you just cant see them. Let us know when you have taken the engine to an engine shop, had it shot peened and magnifluxed, and cleaned. Maybe it will all become apparent. Good luck! If its a 261 its a nice engine!
Deve
The Think Tank
jimbo 24 #1035084 06/12/2014 4:29 AM
thanks dave shot peened and magnifluxed what does that mean
jimbo 24 #1035203 06/12/2014 6:46 PM
U
U Offline
Wrench Fetcher, PhD
jimbo 24 #1035342 06/13/2014 2:45 PM
thanks brad
jimbo 24 #1035745 06/15/2014 5:45 PM
pb1 Offline
Jimbo, got caught up in your thread and one of the pictures triggered me to send you one more bit of info you may need. On the 261's it is crucial to have the oil passages on the block either run direct to each other, or through an oil filter, before you run it. Google chevrolet 261 engine, and you will find this mentioned in several places. Jim Carter has a great article called "The forgotten 261" Good luck with your truck!!
jimbo 24 #1036626 06/19/2014 7:39 PM
thank u. thats what i am trying to figure out now. have oil filter and oil bath. would like to know what goes to that brass line in block. when i opened it, antifreeze came out so i closed it. have no idea what goes to it.
jimbo 24 #1036646 06/19/2014 9:49 PM
jimbo,
Please post again the link to the photo of the brass line in the block.
tclederman #1036774 06/20/2014 1:00 PM
jimbo 24 #1036784 06/20/2014 2:11 PM
" . . . would like to know what goes to that brass line in block. when i opened it, antifreeze came out so i closed it. have no idea what goes to it."
jimbo,
There are two oil filter lines. Those lines should not be to a port that has water inside.
There is a post on the block between the two oil ports. That post is the pivot for the throttle rod bell-crank. If you remove that post/bolt, coolant will come out. Some blocks have holes for two different pivot-post locations - one hole gets used for the post and the other hole gets a pipe-plug.
jimbo 24 #1036849 06/20/2014 10:29 PM
so how do i hook it up
jimbo 24 #1036879 06/21/2014 12:57 AM
jimbo, look close at the end of that stud, the bell crank center hole slips onto the stud, probably with a washer on each side, the spring clip on the end holds it in place, the rest of the linkage hooks to either end of the bell crank to change the direction of motion between the pedal and the carb .... if you had that stud out [to find water behind it] best to insure you put some type of sealer on the threads
jimbo 24 #1036893 06/21/2014 2:54 AM
thanks bill, but i'm sorry, i am lost do u have a pic
jimbo 24 #1036898 06/21/2014 3:18 AM
...Picture of belcrank ...
...picture...
...picture...
...video...
Note. Above picture is off a 54 car 235 with a 216 manifold
It may or may not apply to you.
Just showing my set up. Use only as reference.
jimbo 24 #1036903 06/21/2014 3:27 AM
thank's dad. now i see. Have to find where i put the parts
jimbo 24 #1036904 06/21/2014 3:29 AM
that video is so cool
Page 2 of 2 1 2
