6 members (gswbbc, tonyt, Otto Skorzeny, baldeagle, 55shaker, DES57), 89 guests, and 3 robots.
Topics128,040
Posts1,055,474
Members48,424
#1036837 06/20/2014 9:14 PM
This pertains to TF trucks. I read all the tips and was prepared for restoring everything in the doors for the windows and vent glass.
I am using all parts from Car and Truck in Orange Ca.
Everything worked great, and yes, you might as well trim the clips on the window wipes to start with. But another thing I ran into: was the curved ends are supposed to run behind the big window run. This caused a problem with installing, and also caused a "binding" spot for the window frame.
What I did was carefully make a mark on the wipes and cut them off even with the window run, using a cutoff wheel. (the same one used to trim the clips)
This solved two problems at once. Easy installation & no binding.
Thanks for the tips from everyone on other things. After painting the door, I only spent about 2 hours getting every thing back and DONE.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Sir Searchalot
Sir Searchalot
Yes, I did that also. I think I was able to tuck just a little. Used regular tin snips to cut off.
Moderated by  ndkid275, Phak1
