5 members (J Lucas, Lugnutz, Otto Skorzeny, Steelonsteel, Rich'sToys), 94 guests, and 2 robots.
Topics128,211
Posts1,057,472
Members48,473
I have a question about my pinion oil seal. First off I changed it 8 years ago and it started to leak again, so I pull it apart and found two things: #1 I think I put the oil seal in backwards because I'm pretty sure the lip goes towards the oil. #2 I have a small groove on the drive shaft yoke. So here is my question, should I put it back to gather with new felt seal and oil seal with oil seal facing the right way or should I leave the felt seal out moving the oil seal off of the groove in the yoke shaft. I really cant see a reason for the felt seal with todays oil seals. Thanks in advance guys!
Riding in the Passing Lane
I agree. You don't really need the felt seal. If you can position the seal so it works on an unworn part of the yoke it should work. You probably can get a speedy sleeve for it but I would try the other first.
1972 Chevy c10 Cheyenne Super
I have a speedy sleeve on mine and I just replaced the seal. In order for the lip to face the right way, my seal was mounted with the open end towards the inside. In other words I had to use my driver on the open end of the seal. I found a 3" to 4" transition plumbing part at Home Depot that made a perfect driver.
I don't think the felt is used these days.
1951 1 Ton Completed
Well I got the new seal in and I left the felt packing off, so it moved the new seal off the small warn spot on the yoke shaft. When I was putting the yoke pinion nut back on I had to really crank it. The book says between 160ftlbs-280ftlbs. It fell between notches on the castle nut at 160. So my torque wrench bottomed out at 250 and it almost got it so I could get the cotter key in. I had to go just a little more, I know that I have to be close to the 280 mark. I hope the pinion bearing dose not hand grenade when I take it out for a spin lol.
It will be fine. The spacer determines the preload on the brgs.
