| | | Forums66 Topics128,051 Posts1,055,710 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | Looking to add Clearance lights to my 1 ton, was there a standard location the factory or dealer installed them at? I have seen many different combinations. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the current "standard" is set by your motor vehicle authority [fed now I'd think] and what you should go by as they are for identification in poor visibility conditions - and really not appropriate for pickups
generally "clearance" lights are single ones, as near to the outer edges as practical, and "marker" or "identification" lights are 3 in the center, 3-6" apart - so 5 across
Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | 25.13 Identification Lamps. All buses, trucks, and truck-tractors 80 inches wide or wider must be equipped with three (3) identification lamps of amber color mounted on the cab of the ve hicle, one (1) as close to the vertical center line of the vehi cle as practicable and one (1) on each side of the center line, not less than 6 inches or more than 12 inches.
If your vehicle has dual wheels, it probably is 80" wide. | | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | Have seen factory ones on the smaller 1 ton duallys and the 1 1/4 trucks. My 49 GMC 250 is single with the optional 9' bed. Was just interested in whether there was a template or actually factory location dimension they installed them at. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any given year the factory installed them as required by the laws in the area the truck was to be sold, it wasn't a GM decision or an option, cren cites the correct locations for the ID or marker lights, clearance lights are as close to the corners as you can get ..... aside from having duals those "smaller" trucks no doubt originally had flat/stake decks 6.5' wide with clearance and ID lights on the back as well, for the intended purpose .... which doesn't rule out the possibility that many of the trucks you've seen had lights added by owners, I've seen 1/2T trucks with half a dozen lights evenly spaced across the front of the cab roof
Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If your vehicle is a pickup with a 9' box and single wheels, I doubt that lights were were an option because it never fell within the 80" requirement. However, this cab was used on trucks that were over 80" wide. Texas required a light on each side which were known as clearance lights. The 3 lights in the middle are known as identification lights and were not required in Texas. Other states had other regulations. Back then, trucks engaged in interstate commerce were regulated by the ICC. If you want lights, I would follow current regulations. Clearance lights on each side and 3 identification lights no less than 6" and no more than 12" apart. This is a pretty simple bulletin on what is law now in the US and in Canada. http://www.nhtsa.gov/cars/rules/standards/conspicuity/TBMpstr.html | | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | Thanks Guys, STOVEBOLT never falls short of information.
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | My 57 2ton has 5 amber lights across the top of the cab. When I removed them to restore, they looked like they had been there since 1957.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | It's not a Bolt, but I have a 59 F-350 parts truck that also has either 5 or 6 lights across the front of the cab, all equally spaced. | | |
