0 members (),
80
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | When I bought the truck the right rear brake was tight, now it has seized. Any tips on how to free it up so I can remove the drum?
I will be replacing all the brake lines and possibly some of the cylinders. I have seen the part #s on the GMC 550 post, are those parts listed available in Canada? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Greengrass, Lordco has some of those parts in stock, and could probably get what they don't already have in stock, hope that helps. | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | Thanks Bobb, next time I'm at Lordco I'll ask them. I did get all my 347 V8 ignition parts from Lordco, they had most parts in stock and only needed to order the dist. cap. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Sometimes you can remove the axle and then take the outer bearing out, then you can get enough movement to get the drum and hub off. | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | Thanks Don, I'll give that a try. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Have you tried to back the "Star adjuster" to the "Max".? We did this on the Viking 60 bus,and with a little coaxing from a 10# sledge,we got them off. The hub formed a ridge around the outer circumference,and we had to clear that ridge. Hope this helps.
| | | | | Joined: Oct 2013 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 23 | On the 59 Chevy 10400 that I had, I had to do the same thing on both rear drums. Jacked it up, pulled the wheels, removed the axles and outer bearings. Then, I took some 1/2" socket extensions and worked them into the opposite axle. Once seated against the axle, I had a crowsfoot puller (the kind you use to pull a harmonic balancer) that just fit into the bolt pattern of the drum and cranked it up hard, used a big hammer and after a bit, they finally walked off. Fun job. | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | Thanks WetWilly and Mr. Olds88, I will try all these things. My truck has Daytons and I was hoping to free up the brakes without removing the wheels but I think that will be the only solution. | | |
