5 members (mick53, Grandpa C., lumbersawyer, Nick in Manitou, Wally / Montana), 127 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
#1035785 06/15/2014 10:22 PM
1950 3100
Replaced front wheel cylinders 300 miles ago. Brakes seemed to function acceptably.
Was not able to drive truck for about 3 weeks.
Took her out one afternoon and found that I had a hard pedal and brakes were dragging.
Jacked up front end of truck and found that driver side wheel was locked up.
Pulled hub and sure enough shoes are locked.
Master cylinder seems to function.
Could I have purchased a defective wheel cylinder?
Thanks for any info!
Kurt
could be the wheel cylinder, but also could more likely be the rubber brake line on that side, if it hasn't been replaced
If you mean the shoes were out of the retracted position then you should crack the bleeder to see if they move back in. If they move there is a something blocking the fluid from leaving the cylinder. It could be the hose or a piece of rubber form the hose could have lodged in the wheel cylinder.
1951 1 Ton Completed
Riding in the Passing Lane
Your master cyl. pushrod needs adjusting. There should be a small amount of play before it contacts the piston.
1972 Chevy c10 Cheyenne Super
