1 members (IHPWR),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I am routing four wires from the Basic Classic Parts harness to the tail lights: Two 12g signal wires, and two 14g stop/running lights. When I get to the back, how do I connect the three wires that are routed to the right tailight to the ones for the left side? It seems like I need something like a "T". This may sound easy, but I'm new at this. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes a T or other type splice - the ideal way would be to solder good quality bullet connectors on the wires [2 wires in connectors where needed] and plug them together so they can be opened in the future - can also solder the wires together and cover the joint with heat shrink tubes
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should have 3 wires to the rear. L & R brake/signal and tail light. Your 4th wire may be for an auxiliary brake light.
There should be 2 wires going to the right side, R brake/signal and tail light. You need to figure why you have 3. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | As Red58 said, the harness you bought should be terminated with male bullet connectors. The tail light, brake light wires and wires to the separate directional signal lights should also have male bullet connectors.
You can buy female bullet connectors at your flaps that will do single or double connections.
Then make a mini 3 wire harness with male bullets on each end to go across the cross member to the lights on the other side. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe an add-on signal setup? one brake light wire, one tail light wire, R&L wires to separate turn lights
Bill | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yes, you only use 3 of the 4 wires. White wire not used with turn signals. Wire the common tail light wire first to the left light and then a jumper to the right light using the excess wire of same color. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I'm new at this, is a jumper the same as a three wire harness that was suggested? I need instructions or a sketch.Thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a "jumper" is interconnecting wire, as in "jumping the battery" - a sketch: front | w | i | r | e | driver light ----j-u-m-p-e-r---- > pass light
do you have single bulb/dual filament lights? if so, one filament [brighter] is the brake light, which also serves as the turn light, one wire for each side from the signal unit [fed by the brake light switch] - the dimmer filament is the tail, one wire from the light switch, first to the driver side, also "spliced in" there will be a wire to the pass side, so 3 wires from the front .... if you have added on turn lights, there will be a different setup
Bill | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I understand that most bullet connectors are used in audio applications. I have used butt connectors which lock together tighter. Its the same idea however. You can get singles or doubles. PICO makes good ones. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Denny's factory set up. (looks like just brake and tail) http://www.pbase.com/dennygraham/image/121297553http://www.pbase.com/dennygraham/tail__brake_lights&page=allMy not so pretty connection .... It works ...pic.... I have some shrink wrap in place to protect that connection In my pic you might see a 4th wire. It's for the back up Lamp I ran my two wires from the right tail,to the left side at the rear... tucked in the cross member. Tied the tails together at the rear and ran the one wire the the switch The two stop wires run directly to the signal switch since my signal switch had the brake feature incorporated. 7 wire signal switch. Not sure if your signal switch has the same feature. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | If you have a "universal" Chevy Truck harness that fits many years, it is possible that the extra wire is for a back-up light or lights. Chevy keeps some things, like color codes, forever, so this MAY be correct for you, Brown = running lights, rear, DK Green = brake/turn right side, Yellow = brake/turn Left side and Light Green = Back- up. I hope this helps.
best wishes,
Les | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I agree with ^^^^^^ thats the way I will run mine just in case I install back-up lights. Root
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I agree with ^^^^^^ that the way I will run mine just in case I install back-up lights. Root | | |
