5 members (Oswald, FAST55, Bill Hanlon, 2 invisible), 85 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#1033869 06/06/2014 2:50 PM
Have the '61 in the shop for a cab floor and fenders. Have to pull the 235 and finally address the leaking rear main while she's in her underwear. Was considering juicing up my 235 with offy intake dual carbs and fenton headers, and stumbled onto a rebuilt '68 327 that an old guy never installed. Comes with a 700R4. Way cheaper option than 235 upgrade, and I always wanted overdrive. So research on '60-'62 V-8 motor mounts has led me to a state of confusion. Is there a simple answer? The 235 itself was not easy; I had to have the front mount re-vulcanized because I couldn't find a replacement.
Ray
Might want to post in the engine forum. Might get some help there. I can't help, but it sounds like to fun project.
Hambone
~ HB
1962 Chevrolet C10
1962 Suburban
the engine would have used a mount very similar to what your 235 had, and if I remember right the rubber pad is the same between the two.
I'm thinking it's the same. My 64 had a 327 and th400. Sweet little cruiser. Best of luck to you.
Don't bother trying to use the original mounts with the V-8 and 700R4. It will not support the engine and trans correctly as there is too much distance between the front of the engine and the rear of the trans. There are numerous aftermarket suppliers that sell tubular cross members for this purpose. One mounts to the center of the engine the other on the rear of the trans. You will likely have to remove the existing rear cross member.
Fred
