0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1032291 05/30/2014 5:59 PM
Hey there guys, I have been picking away at my 1957 gmc 9430 project and came upon yet another question. I am in the process of swapping out the rear end and getting the suspension all set up. Now, for the question. Looking at the rims on the truck, they appear to be original, I think they are 17", and have gmc hub caps on them. Is it possible these are not split rims? I see somewhat of a ring around the outter edge of the rim, but that ring is solid and doesn't have a slit in it like I have seen on the few other spilt rims I have ever seen. Any thoughts? Thankyou in advance
Squint29 #1032295 05/30/2014 6:20 PM
17" will be a tube-type multi-piece wheel, and 17.5" will be tubeless one-piece.
They may be three-piece wheels (I know that at least a lot of the 60-66 era 17" wheels were). If they are, there will be a big snap ring in between the outer rim/ring and the center/rest of the wheel. EDIT: And the outer ring/rim will be a solid/continuous ring as you described.
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
Squint29 #1035388 06/13/2014 7:59 PM
V
VEW Offline
V Offline
My 59 1T has 19.5 wheels.
~ Victor
1957 3100 - moved on
Squint29 #1035685 06/15/2014 9:36 AM
my 52 1 drw had 7.00 or 7.50 18".whole truck is bone stock.vew did your rig come out with that size rubber?
Moderated by  Dusty53
