10 members (Gdads51, Forty9, TexasJim50, TooMany2count, 55shaker, Guitplayer, Otto Skorzeny, Peggy M, Bill Hanlon, cmayna), 145 guests, and 3 robots.
Topics128,259
Posts1,058,292
Members48,485
#1035598 06/14/2014 10:26 PM
What is a good oil weight for the 235? I'm currently using 10w30. I live in Southern California with very mild temperatures.
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #1035604 06/14/2014 10:52 PM
1 Offline
I am using Rotella 15-40 oil because it has a fair amount of ZDDP for the cam and mechanical lifters in my 1958 235 engine.The truck is not taken out in our Cold /Snow/Winter road salt season. There probably are 1000 different opinions on this subject. Jerry
MarkT #1035615 06/15/2014 1:02 AM
10W30 will be just fine. Don't read too much into all "the sky is falling" hype about modern oil in vintage engines. On a broken in stock engine, the current SN grade oil will not cause any problems.
Bill Burmeister
MarkT #1035619 06/15/2014 1:28 AM
Gas Pumper
Gas Pumper
I decided after breaking the engine in, my 261 deserved the ROYAL treatment. I use 10w30 in central Kansas it works best I think. But whats more important than the oil viscosity is the COLOR. When I have a drip on my concrete, I want to know what it is.. brake fluid, tranny fluid, whatever. So, Royal Purple 10w30 synthetic. Problem is, I don't have any leaks so far! Here is to hoping my problem persists!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
MarkT #1035798 06/16/2014 12:03 AM
I'll stick with the 10w30. Been using it since I got the truck. So far the only leak I've had (knock on wood) was from the oil canister due to a bad gasket.
