| | | Forums66 Topics128,272 Posts1,058,316 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | What is a good oil weight for the 235? I'm currently using 10w30. I live in Southern California with very mild temperatures.
Thanks. Mark | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I am using Rotella 15-40 oil because it has a fair amount of ZDDP for the cam and mechanical lifters in my 1958 235 engine.The truck is not taken out in our Cold /Snow/Winter road salt season. There probably are 1000 different opinions on this subject. Jerry Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 10W30 will be just fine. Don't read too much into all "the sky is falling" hype about modern oil in vintage engines. On a broken in stock engine, the current SN grade oil will not cause any problems.
Bill Burmeister | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I decided after breaking the engine in, my 261 deserved the ROYAL treatment. I use 10w30 in central Kansas it works best I think. But whats more important than the oil viscosity is the COLOR. When I have a drip on my concrete, I want to know what it is.. brake fluid, tranny fluid, whatever. So, Royal Purple 10w30 synthetic. Problem is, I don't have any leaks so far! Here is to hoping my problem persists! | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'll stick with the 10w30. Been using it since I got the truck. So far the only leak I've had (knock on wood) was from the oil canister due to a bad gasket. | | |
