| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 25 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 25 | Hello all! I just recently became the proud new owner of a '55 LCF flatbed thanks to Materman's Craigslist link post. It is missing the d/s front wheel and is a 5 lug 20" wheel. Would I be limited to finding a 5 lug, or would a 10 lug work using every other hole for a nut? The spacing is 4" CD from one lug to the next & 7" CD across from one to the third one, skipping one, if that makes any sense. (It always sounds better in my head & loses something in translation when it comes out my fingers). Just need something to help load onto the trailer & then I can get more specific about something correct when I get it home.
Thanks, Gary
When I get a headache, I take 2 aspirin and keep away from the kids like it says on the bottle.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If it is 5 studs, it is probably a 10 hole hub piloted wheel. On the drive axle, they used all 10 studs. On the steering axle they used every other hole. GM used this wheel from 55.2 and many years later on their 2 tons. | | | | | Joined: Jan 2011 Posts: 25 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 25 | Thanks! I knew someone here would have the answer and come to the rescue.
Any idea where I could find one of the wheels like that relatively local-ish?
Thanks, Gary
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Salvage yards really don't have anything like that any more. Barn finds and junk yards in small towns are your best bet. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I have a spare that I can part with,(3-piece,NO RH5),for the cost of shipping. It may cost a bit to ship from Iowa,so that's the reason the rim is FREE. (Just in-case you can't find one locally) "Bolters helping Bolters" (319)363-0338-Please leave a message. I'll answer A.S.A.P.
| | | | | Joined: Jan 2011 Posts: 25 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 25 | Thanks for the offer wetwilly! That's very generous. I'll scrounge around here for a day or two and may be giving you a ring.
Thanks, Gary
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I'll be here! Good LUCK!! "Materman"'s truck might be getting one of '"Tater"'s "shoes!! Too Cool!
