| | | Forums66 Topics128,007 Posts1,055,278 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | can someone tell me whatgoes into the water pump outlet. is it a nipple then a hose thanks pic
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | One of the heater hoses attaches here with a clamp. I guess you'd put a pipe plug in it if you don't have a heater.
John | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | john i do have a heater but is there a fitting or nipple that screws in | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, either a piper plug or a heater hose fitting goes there. The size of the fitting is dependent upon the size of the water pump holes and the heater hoses/fittings (year and size of engine). 5/8" fitting 5/8" fitting 3/4" fitting Most local parts stores should have them. | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | | | | Joined: Feb 2014 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 46 | water works heater better if ya pump it up through heater core.im not sure but i think presure is from water punp side. all you need is pipe thread on one side and barb/hose on other end of fitting.good luck on you project
