Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TUTS 59, walter74, 1955 1 Series, 51sub, farmallb, 1 invisible), 42 guests, and 2 robots.
Topics128,005
Posts1,055,256
Members48,418
#1035482 06/14/2014 6:11 AM
can someone tell me whatgoes into the water pump outlet. is it a nipple then a hose thanks pic
jimbo 24 #1035503 06/14/2014 1:37 PM
One of the heater hoses attaches here with a clamp. I guess you'd put a pipe plug in it if you don't have a heater.
jimbo 24 #1035546 06/14/2014 5:05 PM
john i do have a heater but is there a fitting or nipple that screws in
jimbo 24 #1035548 06/14/2014 5:13 PM
Yes, either a piper plug or a heater hose fitting goes there.
The size of the fitting is dependent upon the size of the water pump holes and the heater hoses/fittings (year and size of engine).
5/8" fitting
5/8" fitting
3/4" fitting
Most local parts stores should have them.
jimbo 24 #1035629 06/15/2014 3:26 AM
thanks tim
jimbo 24 #1035693 06/15/2014 10:29 AM
water works heater better if ya pump it up through heater core.im not sure but i think presure is from water punp side. all you need is pipe thread on one side and barb/hose on other end of fitting.good luck on you project
jimbo 24 #1035832 06/16/2014 2:47 AM
thank u
