0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What is the going rate for a rebuildable 848 head for 235-261. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Cheaper to buy an entire motor from some guy switching to V8. Check over on www.trifive.com.Best of luck Jim | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | The key is don't tip your hand by asking for an 848 head. Ask for 56 and later head, and don't start drooling all over yourself when you find one. Chances are most people don't know what an 848 is.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Buyer beware though. It has been my experience that about 60% of all heads from that era are cracked and non-serviceable. I would be purchasing an 848 from a reputable engine shop or someone who guarantees the serviceability. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The key is don't tip your hand by asking for an 848 head. Ask for 56 and later head, and don't start drooling all over yourself when you find one. Chances are most people know what an 848 is. Just say you are looking for a 56-63 235 head. The 848 heads were the most common high-pressure 235 heads - roughly 75% of the heads. I think the drooling over an 848 head is drooling over one that has no cracks and has been certified/tested/guaranteed for no cracks, as Deve pointed out. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | What makes these heads so prone to cracking?? John | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The early Ford V-8's had similar problems but worse since there was no head. For its time, without computers, they did pretty good at designing engines, but they are vintage so its just expected that they really didn't have the tools at the time to understand metallurgy, heat transfer, etc relating to longevity.
Yet, think about what they accomplished. At the time, most people changed vehicles every 3-5 years and they managed to create heads that can be found good 60+ years later. I could bring up the Vega and its 4 cylinder alum engine. If you can find the CAR these days you are lucky.
Just be aware that when you buy a head, you have a 40% chance of it being usable. Unless its guaranteed, forget it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 40% I have friends in VA who used to say 80% | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If I I'm right,George probably has a few to sell. what are they selling for? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Other than compression ratio, what is different with these heads? Could a '54-55 head be surfaced to raise the compression. I had a 1953 low oil pressure engine that had a crack in the #5 cylinder between the intake and exhaust seats..... Other than that it was a good engine. I should locate another head for it...
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Unless you are going to Bonneville to set a new land speed record I don't believe you could tell the differance in compression. Fact is most V8 folks detest the inline six and are happy to have you haul it off. I've had a few perfectly good 235s given to me. The 216 heads now I believe are the most difficult to find in usable condition. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I was going to junk a 216 engine I have down in the garage, but after reading different posts over the last year or so I figure maybe I'd better hang onto it. Someone might need one...
I think I might have an extra 216 head around or not....
John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I had a 1953 low oil pressure engine that had a crack in the #5 cylinder between the intake and exhaust seats..... Other than that it was a good engine. I should locate another head for it...
John A 1953 splash 235 uses the same head as all full pressure 235's except it is not drilled for the four bolt valve cover.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I have a head here off a 1954 engine.... Would the rocker arm assembly fit? maybe the '53 engine doesn't have the correct head on it then. I don't believe it has the 2 acorn nuts holding the valve cover on. Now I'm going to have to walk down to the shed and look...
John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 1954 18-bolt 235 head (high pressure 235 engine) will work on the 1953 235 engines (on both high pressure and low pressure 1953 235 engines). The 1954 head's valve cover attaches with 4 machine screws on the sides. The 1954 head's valve cover attaches with two bolts/nuts in the center/top.
The rocker arm assembles (and oiling connection) should work interchangeably (Pre '68 Dave would know for sure).
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1950-58 235 rockers will all interchange. The only difference is the rocker supports. The 1950-53 bolts that hold the rockers to the head are shouldered bolts and the supports have a larger hole in them for the shoulder as do the shafts. Starting in 1954 the shoulder bolt was dropped and a smaller hole in the support and shaft was used. It is no problem using the earlier supports on the 54 and later engine. Either use the shouldered bolts or just split one rocker support on each shaft so it pinches down on the shafts to keep them from moving Sample. Chevrolet even sold this style of split support as a replacement Sample In fact I do this on all of the engines I work on no mater what design to prevent shaft movement.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If I I'm right,George probably has a few to sell. what are they selling for? I think the price is rising with the length of this thread What are they going for? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | If I I'm right,George probably has a few to sell. what are they selling for? I think the price is rising with the length of this thread What are they going for? LOL...... John | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | 1950-58 235 rockers will all interchange. The only difference is the rocker supports. The 1950-53 bolts that hold the rockers to the head are shouldered bolts and the supports have a larger hole in them for the shoulder as do the shafts. Starting in 1954 the shoulder bolt was dropped and a smaller hole in the support and shaft was used. It is no problem using the earlier supports on the 54 and later engine. Either use the shouldered bolts or just split one rocker support on each shaft so it pinches down on the shafts to keep them from moving Sample. Chevrolet even sold this style of split support as a replacement Sample In fact I do this on all of the engines I work on no mater what design to prevent shaft movement. Thanks Dave and Tim..... John | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If I I'm right,George probably has a few to sell. what are they selling for? Right. John just pulled one off a blown engine he got at the Sedalia swap meet. I have an add in the "parts for sale" section. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Over the years, the 848 has become the gold standard of 235/261 heads, so when I do engine rebuilds, I know I will be more popular with the purchaser if it has an 848 on it. As Tim mentioned, 75% of all 235 heads are 848 so its not hard to find them. I have four untested 848's and my hope is two of them will be good. I am not holding my breath. My 261 sports an 848 with the extra holes drilled. The first two I gave the engine shop were bad. | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | So how can one tell if you have an 848 head? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | So how can one tell if you have an 848 head? look for the casting number Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Okay while on the subject of heads. Were 216 heads and 261 heads also crack prone??
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The reason a 235 head (848) is on my 261 is that I couldn't find a good 261 head. Turns out the 848 is better anyway, but you DO have to modify the head by drilling a few holes. I THINK those holes are for water passages, but I don't remember for sure. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Boy were full of good news...... :-( John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Try to find a head for a 1927. I had to go through 5 hard to find heads before I found a usable one for a recent job.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Try to find a head for a 1927. I had to go through 5 hard to find heads before I found a usable one for a recent job. 1927, that would have been a 4 cylinder.... They had open pushrods didn't they? John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Yes, 1928 was the first year to have a side cover, or should I say side covers.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Well yippie, i just checked the head on the 235 i have in a cradle for my 52 3100 and lo and behold its an 848. Now i just hope there is nothing wrong with it as i havent disassembled the motor yet.
Joe | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Well! I did a close inspection on the one I had & it is cracked. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'll find out in a week if the one I have is cracked.
