Was doing some research and was wondering what the Factory Setting for Timing are for my First Generation 1929 194CI 6-Cylinder.
I have an Old Document Titled "Specifications International Jan. 1, 1929" and it list the following:
...Spark Control Type: Semi-Automatic
...Firing Order: 1-5-3-6-2-4
...Timing, Spark Advanced: 12 Degree BTDC
...Distributer Interrupter Point Opening: .030
Then on Another Paper titled: "Standard Auto-Electrician's Manual" dated 1929:
...Spark Plug - Gap: .025
...Breaker-Contact Separation: .018 - .022
I know the Most Common recommended Settings are:
...Spark Plug - Gap: .040
...Timing, Spark Advanced: 18 Degree BTDC
I would like to know what everyone's View is on the Chevrolet Factory Settings for:
...Spark Plug - Gap: _____
...Breaker-Contact Separation: ___
...Timing, Spark Advanced: __ Degree BTDC
trying to get back to my 1929, want to set it up to Factory specs get it right, then venture over to the Most Common Recommended Specs.
Also read in a Post about going to .045 gap on the plugs, and may run smoother/ happier ?? Any thoughts on that or test, trials ??
I am currently using AC Delco C86 plugs, but also understand a modern day substitute would be the C87 Plugs which are readily available, would the C87 follow the same guidelines as the C86 ??
