5 members (KEVINSKI, FAST55, rfs56trk, Joe H, Danielbolt), 81 guests, and 3 robots.
Topics128,094
Posts1,056,487
Members48,444
#1035316 06/13/2014 10:44 AM
Having trouble finding correct front wheel bearings for my truck. Everything NAPA has is either too small or too big. The bearing suppliers locally come up short on the barrel type as well. Good online supplier? Thanks much.
1946 Chevy 2-Ton
More pix in Flickr
1966 Chevrolet L60
More pix on Flickr
__________________________
Whoa! That can't be right!
I went through the same thing with the '48 2 ton.
My bearing shop was able to locate some, but didn't want to get them because the price was insane. In the range of $300 per bearing. I couldn't find any other suppliers for new parts.
I found some NOS parts on Ebay at normal prices.
If I hadn't, the next step was to convert to tapered rollers. There is no drop in match. My bearing shop is really good at working with customers and was sure we could find a combination of SAE and metric parts that would work and only require me to do a minimum amount of machining to modify the hubs.
I just got the front of my '46 2 ton back together. I had no idea that the bearing would be such a big ordeal!
I found the inners on Ebay and picked up the outers from Chevs of the 40's. Not cheap, but they had them in stock somehow.
Do you know the part #'s? Are they the same as mine? I might be able to help you.
1946 Chevy 2-Ton Rat Rod Wrecker
Both are made by HYATT. The outer is an "A-11035". The inner is an "A 11424". The inner seal is an "11424-Z". I have yet to look at my Chevy parts book for the GM numbers. That is on for this weekend. Thanks for the help!
1946 Chevy 2-Ton
More pix in Flickr
1966 Chevrolet L60
More pix on Flickr
There are a lot of early 50's Chev and GMC farm trucks being sold in the Midwest for little more than scrap iron price. I would not hesitate using good used bearings. As long as they have oil and no water, they last almost forever. I recently bought this one in Kansas for $1,000.
https://picasaweb.google.com/108197...vEQ&noredirect=1#6002347299271685330
The cab would look good on a pickup and it has a good running 270.
Now that was a nice truck find!
1946 Chevy 2-Ton
More pix in Flickr
1966 Chevrolet L60
More pix on Flickr
