5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#1035160 06/12/2014 4:03 PM
I am going to look at a 1961 C10 with a 235 and 3 speed transmission this weekend. He says the 235 is stuck and he was going to put another engine in but not enough time or money for the project. I did find someone selling a running 1957 235 with a powerglide. Looking through past posts it seems there are differences between the 235's especially in car/truck applications. Would the 57 235 work in the 61 C10 with the 3 speed?
According how the '61 235 is mounted in the truck frame. If it has the front mount and clutch housing mounts like the earlier trucks, then you'd need to swap the front plate and the clutch housing with the '57 engine you are installing. You would also need to a pilot bearing in the crankshaft flange for the input shaft of the transmission. And of course change the flywheel from the '61 engine.
i personally knew of a 57 283 that had a powerglide behind it.hole was never machined for pilot bushing.with high compression,hot cam,forged pistons,it came undone.car was flying,tryed for 2nd gear and car scatered clutch.be safe and check 1st. gl on your bolt
