4 members (Hotrod Lincoln, Canadian Dump, Dennys28, Phak1), 130 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
Does anyone have photos of the radiator support mounting bolts, pads and shims? For a 52 3100 1/2 ton chevy.
joe
bolts and pads, don't know about shims, but body type shims are available at any FLAPS
Thanks bill
I don't have any photos either, but the carriage bolts (3/8" I think) drop in from the top. I used nyloc nuts on the bolts as you are not supposed to put more than 5 lbs torque on the nut (IIRC). I had to add 1/4" of shims (in addition to rubber pad) to get the hood and fender fitment the best I could. I made the shims from aluminum flat bar stock.
Thanks david, im pretty sure i found the original carraige bolts, there were two shims and one pad with them but no nuts.
Good to have original. Mine were almost worn in half from the radiator support moving around before I purchased the truck. I think the originals were fine thread and used a castle nut and cotter pin.
